what diff to use 3.91 or 3.64
3.64 or 3.91 Diff
3.91
7
35%
3.64
13
65%
Total votes: 20
Wed Nov 30, 2011 8:37 pm
What diff should i use with this setup
Car in quesion is a touring with a 325i Engine and 320i Gearbox
Now do i go for a 3.91 Diff or a 3.64 Diff
can you get both as open diffs ?
Grrrmachine
E30 Zone Wiki / Team Member
Wed Nov 30, 2011 8:44 pm
The 320i gearbox will give you sport ratios, so I think you'd be better off with the lower diff. That way you'd still have perky acceleration but with a good cruising MPG, which is what you want from a touring :D
A 3.91 might make 1st gear redundant with that setup.
Wed Nov 30, 2011 8:50 pm
what are facelift sports like as they have a sport gearbox with 3.91 are they pretty much too revvy through 1st and 2nd
Ajsingh
Wed Nov 30, 2011 8:53 pm
I run a 3.91 with my 2.7 and its great fun! 70mph is 3000rpm on motorway and its great fun around town. Late 325i sports came with 3.91 LSDs so id go for a 3.91. A 3.64 will be great on a motorway run but maybe abit long
Yea both are available LSD and open
I love my second and third gears, the pull is great! And IMO its not too revvy! And it was running a 4.10 diff! Lol
The 3.91 IMO is a good all rounder, offers good off the line speed, fun around town and gives good motorway mpg and keeps the revs low
Edit... My spec is 2.7 engine, 320i gearbox and 3.91 LSD = great car to drive
E30 Crazy!
Wed Nov 30, 2011 9:09 pm
50/50 so far :cry:
Sanchez
Wed Nov 30, 2011 9:17 pm
not any more.
Ive got a touring with 2.5 engine and 2.0 box, current diff is 4.10 open but 3.91 LSD in the garage to be fitted.
Im gona pick up a 3.64 open if one comes for sale cheap enough then i can see whats better for me.
Wed Nov 30, 2011 10:08 pm
where's the 3.73 option :?
Wed Nov 30, 2011 10:11 pm
3.91 will light up a bit easier but the 3.64 will be better on a cruise/ day to day job,
the 320 box will only give you a higher first and poss second gear the final drive in 5th will be the same as a 325 box IIRC
3.91 were fitted to tech 2's
3.64 were fitted to tech 1's, your going to be running pretty much the same set up as the old sport on this ratio alex :D
most tourings got a 3.73 which is a very nice all round diff :D
Wed Nov 30, 2011 10:26 pm
are 3.73 open diffs easy to get hold of forgot about them
Wed Nov 30, 2011 11:01 pm
you have 3 months to find one :)
Wed Nov 30, 2011 11:15 pm
Where's the M50 option..? :)
Wed Nov 30, 2011 11:42 pm
e30topless wrote:most tourings got a 3.73 which is a very nice all round diff :D
The standard ratio for a 325i touring is 3.91 auto or manual.
3.73 is the ratio for post sept '87 non sport 325i saloons and cabrios with an auto box.
They are rarer than 3.64 and 3.91 in LSD form.
Wed Nov 30, 2011 11:44 pm
Obviously my car runs a 3.91 and driven back to back with 325i's with a 3.64 the acceleration difference is noticable but then so is the fuel economy!
Thu Dec 01, 2011 7:02 am
What are you going to use the car for mainly. If it's an everydayer then a 3:64. If it's a "hooning about loons tool" then a 3:91.
Thu Dec 01, 2011 5:19 pm
a 3.91 is a sh!t diff. 1st is non existant and they're revving their nuts off on the m-way. If you want 22mpg everywhere you go even on a run then fit one.
3.64 no brainer! The difference in acceleration is nothing to write home about, Barry is being picky over 0.3 of a second. The car will drive so much nicer with this ratio plus you'll get some economy when on a run not on a charge
Infact with 3.64 you'll hit 60 in 2nd i expect!
Andyboy
Alpina Colada
Thu Dec 01, 2011 5:20 pm
325i manual Tourings use a 3.91. Not a bad diff but too revvy for the motorway. I put a 3.64 in mine which made it a lot nicer to drive.
Dezzy
CR24v it's a lifestyle
Thu Dec 01, 2011 5:22 pm
my 325i se had a 3.64 when i bought it.
It was the best of both worlds imo.
Thu Dec 01, 2011 5:23 pm
auto 325i tourings also use a 3.91
Thu Dec 01, 2011 6:05 pm
3.91 LSD in my chrome turd Alex and it's too revvy on motorways and even driving around town you are doing a lot of cog swapping. I'm usually in 4th gear by 40mph
Thu Dec 01, 2011 7:20 pm
My 2.7 runs a 3:64 LSD and even as an auto, it's still good.
Personally, I think a 3:73 is a good alrounder but theres naff all difference really between the two.
Ajsingh
Thu Dec 01, 2011 9:39 pm
Lol alot of hate against the 3.91
I quite like mine. 3000rpm at 70mph, not quite very revvy as mentioned
What does a 3.64 do at 3000rpm?
E30 Crazy!
e301988325i
currently on 3.64, quite tempted to swap for 3.46 TBH
I said:
e30topless said:
lock the wife in there
Thu Dec 01, 2011 9:42 pm
Decision made 3.73 it is :D
Sanchez
Thu Dec 01, 2011 9:46 pm
Ajsingh wrote:Lol alot of hate against the 3.91
76.25mph winkeye
Sanchez
Thu Dec 01, 2011 9:48 pm
and 3.73 will give 74.41 all with 2.5 sport engine and gearbox in 5th gear.
Thu Dec 01, 2011 10:12 pm
2500rpm, much nicer how does 3500 at 90 sound? bit better than 4000rpm!
Dezzy
Thu Dec 01, 2011 10:37 pm
I found first gear too short with the 3.64 fitted, whats first like with a 3.91?
Ajsingh
Thu Dec 01, 2011 11:34 pm
Its ok ish i suppose.. I get to about 20mph then gotta change up (anything is better than a 4.10 and 4.27 i used to have)
I redlined once when getting of the line quick and i glanced down and saw 30mph
E30 Crazy!
Ajsingh
Thu Dec 01, 2011 11:35 pm
Oh wow!
Heres me thinking 3k at 70 is good
E30 Crazy!
Andyboy
Alpina Colada
Fri Dec 02, 2011 10:25 am
I restored an early 320i a couple of years ago and that had the original 3.45. It went remarkably well and would do 60 in second just short of the rev limiter.
e301988325i
Fri Dec 02, 2011 1:28 pm
Dezzy wrote:I found first gear too short with the 3.64 fitted, whats first like with a 3.91?
I had the same feeling with 3.64 (open) fitted, fitting a sport c/r gearbox ratios cured first being completely useless, but even now once rolling first is not required, I'd like to swap for an open 3.46.
I said:
pegase747
Fri Dec 02, 2011 2:02 pm
3.73 LSD FTW, I just love mine, with 325i Gbox and the C2 engine...
Pierre
1988 Alpina B3 2.7 nbr 224/257
[img]http://i6.photobucket.com/albums/y228/pegase747
