sorry if its a dumb quation but If i'am using a 325i engine with 320i gearbox what clutch do i need
a 325i one or 320i ????
b25 with 320i gearbox, what clutch
sweep
either alex
Good stuff
i have a half decent looking clutch here with pressure plate and a standard 6-pot fly wheel
+ a yard full of scrap turds
ummmm..... pm on its way
Flywheel, clutch disc and release bearing are the same part number for both engines. The cover plates have different part numbers, which I suspect is a stronger spring in the 325, given the noticeably heavier clutch pedal in a 325 compared to a 320.
given that a lighter clutch is nicer i vote for the 320i oneBrianmoooore wrote:Flywheel, clutch disc and release bearing are the same part number for both engines. The cover plates have different part numbers, which I suspect is a stronger spring in the 325, given the noticeably heavier clutch pedal in a 325 compared to a 320.
