very bad misfire
Ninja_Penguin
Post Mon Nov 28, 2011 3:09 pm
as said in title. i seem to get a very bad misfire but only when its damp out. isnt too bad when i first start up, then get really bad to the point it will run on 1 and cut out. then i leave it sat for about 5mins on tick over and its all good.
could this be just a simple case of needing new plugs and leads?
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Nov 28, 2011 3:27 pm
Unfortunately you can't really TEST the dizzy, but for the HT leads then get it idling in a dark place with the bonnet open, and look at the leads for sparks. Apparently they're pretty reliable on these cars though.
Ninja_Penguin
Post Mon Nov 28, 2011 3:42 pm
i do have a spare dizzy rattling around in the boot. maybe worth fitting it to see if it helps.
Touring_IOM
Post Mon Nov 28, 2011 3:51 pm
Could be the ignition coil. Test to see if its that
mb15
Post Mon Nov 28, 2011 4:14 pm
I've had similar problems and it was the dizzy cap mate. Didn't look too bad but as soon as it was changed i've had no more problems. I only had the issues when it was damp or raining like you, i'd swap out the rotor arm while the cap is off as well.
Ninja_Penguin
Post Mon Nov 28, 2011 10:01 pm
might fly up scrappy tomorrow then, theres a 1.6 touring in there atm so a 3rd dizzy is always good. seeing as ive pilfered it for quite a lot of parts
