black and yellow wire from the engine loom
randomspeedfreak
Post Mon Nov 28, 2011 1:39 pm
I have a black and yellow wire with a ring terminal hanging about in my engine bay. any ideas where this should go?
cheers,
Matt
Post Mon Nov 28, 2011 1:41 pm
Starter motor
randomspeedfreak
Post Mon Nov 28, 2011 1:56 pm
DanThe wrote:Starter motor
sweet cheers dan
out of interest what does it do?
m_jermyn
Post Mon Nov 28, 2011 2:01 pm
Starts the car if its for the starter motor.
Post Mon Nov 28, 2011 2:08 pm
m_jermyn wrote:Starts the car if its for the starter motor.
:rolling:
randomspeedfreak
Post Mon Nov 28, 2011 2:42 pm
theres a connection on the starter motor that cuts power to some of the relays in the fuse box, it could be something like that
dan which terminal?
Post Mon Nov 28, 2011 4:03 pm
Larger 6mm terminal, its the start signal, the smaller 5mm terminal is the unloader Black/Green wire for the relays
randomspeedfreak
Post Mon Nov 28, 2011 7:46 pm
DanThe wrote:Larger 6mm terminal, its the start signal, the smaller 5mm terminal is the unloader Black/Green wire for the relays
okay thanks bro
randomspeedfreak
Post Tue Nov 29, 2011 11:19 am
is the black green the only thing on the smaller terminal of the starter?
