2.7 eta pinking super unleaded petrol?
exup
- Boost Junkie
i m getting all the parts togeter for 2.7 eta , using complete 2.7 eta bottom 1988 and 320 (731 head with 325 valves ), will i have to run on super unleaded all the time , to stop it pinking ?, can any one whos done it let me know?
Ant
- Retired Team Member
you should be OK on normal fuel dude, the 731 head is a good match for the Eta piston shape
keep us posted on how you get on M8
Email FTW
chu346
I'm running the Eta (200) head on standard fuel.
Are you sure the block that you have isn't a super Eta. If so you need a 325 head.
I thought that the 87'-88' blocks were the super Eta engines.
exup
- Boost Junkie
not too sure if its a super eta or not, but how do i tell ?, ? anyone ???chu346 wrote:I'm running the Eta (200) head on standard fuel.
chu346
Have a look what the cast number is on the head. It should say 200 or 885 (probably). The number should be in between ports 3 and 4 iirc.
exup
- Boost Junkie
Cheers i assume if its 200 its a std ETA ?
and if its 885 , its SUPER ETA then, , i itend to start stripping it this week , is the 885 a std 325 head then or was it modded for the ETA ?, IE Smaller valves and ports etc
Templ8e30
99% certain we never got the super eta in the uk.
I'm running a 525e engine with highly modded eta head and normal unleaded is fine although she's more responsive on super
The 731 320i head has the same combustion chambers as the eta head, good choice using 325i valves. Get the valves and seats matched with a 3 angle grind for more airflow and power while you're at it
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
