Mixing conrod big end caps?
Brian28
Post Sat Nov 26, 2011 10:06 am
I've bought some HC pistons with conrods for an M20 build, but the big end caps didn't come with them. Not an issue initially as I was going to use different conrods, but now will likely just use the ones that the pistons are already on. Anybody ever experienced any issues with mismatched caps? I have another couple of donor engines here I can take them from.
Post Sat Nov 26, 2011 6:31 pm
Personally i wouldn't.
e301988325i
Post Sat Nov 26, 2011 6:32 pm
They're machined as an assembly, don't do it, scrap the rods without caps.
I said:
e30topless said:
lock the wife in there
chh137
Post Sat Nov 26, 2011 6:49 pm
definately need matching rods and caps. as above DONT DO IT
Brian28
Post Sun Nov 27, 2011 5:04 am
Kind of what I was expecting. But I was hoping somebody would have done it four years ago, and then used the car for a hundred mile daily commute and track days on weekends ever since, with the bottom end still sounding like new :wink: Ah well, thanks all.
On a serious note, if it was for a road car I'd be tempted to stick them in anyway just for curiosity and by way of experiment. I've swapped over M40 cam caps before (necessity rather than choice), again a factory line bored effort but no ill effects noted when I stripped the engine again after 8k miles.
e301988325i
Post Sun Nov 27, 2011 9:10 am
You could get lucky with the cam, the valve springs mean that the force is always in one direction, where as the recipricating bottom end is pulling one ay then the other. HTH
I said:
