Just bought a brand new wiper motor from BMW. The wipers sweep correctly but when the wipers park they jerk and park slightly higher up the screen than they should. I presume the wiper motor is at fault ?
The wiper relay was changed also.
Wiper Problem
Billwill
You need to remove the wipers off the spline...run the wiper motor and let it stop in the park position. Replace the wipers onto the spline at the correct position near the bottom of the screen.
Not sure about the jerking though.
turkeysneck
I've done that already.
