Cam fitted now vacuum problem.
wjc
Post Wed Nov 23, 2011 11:28 pm
Hi all.
I have fitted a Schrick 284 / 272 cam into a reco head.
After putting the head back on I have found that when I take the oil filler cap off when the car is running it does not effect the idle.
I have checked just about everthing I know of for poss air leaks, I even took the inlet manifold off again to make sure it was all sealed.
Have any of you come accross this problem before ?
