No IGN Feed to pin 7 on c101
darren_mk
Post Sun Nov 20, 2011 2:56 pm
Hi all,
I am working my way through my tech 2 sport project and attempting to start her up.
I have no live to the coil with ign on - and after a search on here i then checked pin 7 of the c101 plug. Its also dead.
I have an ign feed from the loom on the steering column - can anyone help me to where this goes to?
I have the glove box etc all stripped out and there are no traces of any previous alarms/immobilisers.
darren_mk
Post Sun Nov 20, 2011 8:23 pm
Brianmoore? :)
Post Sun Nov 20, 2011 8:51 pm
Hello!
Find the immobiliser socket above the top of the glovebox. It's a two pin socket with a single plain green wire going to each pin.
The other end of one of these wires is pin 7 on the body side of the C101, and the other end of the second one is a soldered joint inside the loom on the driver's side of the car, where the green ignition feed wire to the fusebox tees off.
A few more inches from this soldered joint is the plug and socket half way down the steering column, where all the wires from the ignition switch plug in.
The immobiliser socket should have a plug of some kind fitted into it. What wires come from this?
All the above assumes that no one has been busy with the side cutters at any time!
darren_mk
Post Mon Nov 21, 2011 6:41 pm
Brian,
I cant seem to find the immobiliser socket?
Here is a picture of the area:
There is a 2 pin plug taped to the main loom with a ign feed on it, but is un tampered and as the factory intended.
Am i looking in the right area?
Post Mon Nov 21, 2011 7:20 pm
Up and to the right.
darren_mk
Post Mon Nov 21, 2011 8:52 pm
Thanks Brian for the replys - all sorted now, i had forgotten to plug the OBC brain back in..... :o:
The fun never ends though, as i now have no fuel coming up! - so off to search for troubleshooting that one...
Brian can i ask you about the c/l -
After nothing worked at all, i carried out the red/black wire mod, and re-soldered the thermal fuse on the relay. I now have locking on the drivers door and boot, both with key. The passenger door wont work at all. Whats the best way to test this, i suspect its in the door pin socket, is there a common live / earth to check first?
Post Mon Nov 21, 2011 11:19 pm
If the door mirror still works on the passenger side, I doubt if the door plug and socket is at fault, (unless the mirror feed has been repaired at some time). I'm more inclined to suspect the lock motor itself.
darren_mk
Post Tue Nov 22, 2011 8:05 am
The passenger door wont operate the central locking with the microswitch as well, so thats why i suspect a problem with the wiring. If the motor was faulty would the switch still not send a signal to lock the other doors?
I havent tried the door mirror yet, so will update when i do.
