e36 m42 slightly high idle
northy1983
Hi i have a e30 with e36 m42 lump in it, when starting the car it idles fine just below 1000rpm but after i have been driving the car it idles at about 1100rpm and sits there. Car drive perfect and smooth, idle doesnt dip at all. Looks like there is no adjustment for idle speed as controlled by ecu. Anyone come across this before?
rix313
It's likely the cable is too tight on the throttle body. There is an adjustment screw on the cable where it attaches to the body. Turn it clock wise to wind it in and this will slacken the cable and close the butterfly.
northy1983
ill try that but seems weird that it idles at the right speed when you start it up but then idles too fast once its been driven.
