m20 engine help please
skooshy
Post Sat Nov 19, 2011 7:55 am
right guys my 325i sport devolped a miss fire about 3 weeks ago found out it was no compression on number 5 cyclinder so took head off bent valve but also pushed valve seat out of the head so go it fixed running sweeter than ever before .........
but here comes the sad bid 2 nights ago dwn at asads came out to car started it to hear it miss firing again so home done a compression test and number 5 was ok turned out to be number 6 this time so took head back off last nite and its done the same made contact with the piston bent the valve and pushed the valve seat out of the head again ......so my question is why is my valves hitting the pistons ?????
my timing is stop on and ive set my valve clearences to 24 thou any ideas?????
e301988325i
Post Sat Nov 19, 2011 10:26 am
Someone more knowledgeable may help later, but I expect you oil spray bar in the head is blocked, meaning that your top end is not lubricaed properly, causing the valves to not return home causing the interference of piston/valve then pushing the valve into the head dislodging the seat. take the rocker cover off and inspect the spray bar for gung/blockage.
I said:
e30topless said:
lock the wife in there
