loss a lot of water sometimes and a little, the water come out from the bottom of the reservoir after the car run, but when the car stop after run the water that come out from leakage is more alot.
my mechanic said it is because the thermostat stuck closed, so the pressure push the O ring at the bottom of reservoir. He said that because there is a different temperature between the bottom of the hose and the top hose.
but I feel it is not true as the temperature gauge is always at half at the center and move slightly below the half if run at the highway. As I know clogged thermostat will raise temperature but in this case it is not.
So where the pressure coming from?
1.thermostat stuck closed?
2.hair crack at cylinder head gasket?
(no oil mix with water, but all spark plugs ceramic coloring red like brick and the electrode dark brown)
note : radiator behr made is south africa is new and radiator cap 1.4 bar behr is also new.
any idea?
today, I will replace my thermostat and put a new O ring at the bottom of radiator reservoir.
thank you in advance
markus
Coolant loss issue 318i m40
markus_74
