HELP PLEASE - NO HEAT COMING FROM BLOWERS
- SMALLTHING
- Contact:
Hi, I have recently completed an engine conversion on my e30, and now there is no heat coming from the blowers. any suggestions as to what I have done wrong or what I can do to fix this problem please. I do not want to be left out in the cold this winter with now heat in the car!!!!!!
Curr946
- Contact:
what engine have you fitted?
has it been bleed up properly?
have you got the heater pipes the correct way round? ( the pipe from the back of the head should go to the bottom pipe on the bulkhead )
wheres the temp sitting?
If your wife must learn to drive, don't stand in her way!
- SMALLTHING
- Contact:
Hello the engine is a m52
It has been running sweet just no heat !
The heater temp is sitting at the front where the top hose sits.
I will double check that the pipes are in the right way,
thanks.
- E30 Zone Meets/Events Team
- Contact:
I bet the pipes have been installed the wrong way round to the heater matrix.
If that's been done, you may have damaged the matrix valve too.
- SMALLTHING
- Contact:
thanks for your reply
will check it out thanks
