can you have 2 batteries in a cabriolet????
gingerrusta
Post Thu Nov 17, 2011 10:49 pm
I am having trouble with my battery going flat as im not using my cabby as much as i would like and was wondering if you can put another battery in the boot as well as a back up? If so how would you wire this up ? Ground to a panel and the live back through the car to the exsisting battery maybe?
mrb27
Post Thu Nov 17, 2011 10:55 pm
a trickle charger will be better and cost less than a decent battery+wires
BenHar
Then you'll have two flat batteries.
Ben
mrb27
Post Thu Nov 17, 2011 10:56 pm
lol
gingerrusta
Post Thu Nov 17, 2011 11:08 pm
only problem is the car isnt near any power to run a trickle charger to. Thats why i thought fitting a second battery would help as it would at least have the 12.45volts it needs to start every time.
chh137
Post Thu Nov 17, 2011 11:11 pm
solar power charger?
Post Thu Nov 17, 2011 11:20 pm
I have a solar tricke charger on the cab while its locked up for the winter, so far so good, battery seems fine, and the alarm is on too.
**BANNED**
Post Fri Nov 18, 2011 12:57 am
Think KISS,(keep it simple(I'm)stupid.
Solar charger for under £20,just needs to be in sight of sunshine!
Youth is wasted on the young.
HairyScreech
Post Fri Nov 18, 2011 3:12 am
or even more simple, a battery cut off switch.
just cut the battery power via the switch when leaving it for any length of time.
gingerrusta
Post Fri Nov 18, 2011 7:51 am
Cheers guys the solar charger sounds good. Where did you get that from Rav?
Post Fri Nov 18, 2011 8:34 am
This one.
http://www.ebay.co.uk/itm/Solar-12v-Vol ... 3f0fdca1b1
Malc, it needs "Light " to work, not direct sunshine, and gives out a suitable charge. :D
**BANNED**
Post Fri Nov 18, 2011 11:20 am
Rav335uk wrote:This one.
I use solar power on my sailing cruiser,whilst I agree that 'light' will give a small charge,sunshine will give a far better rate of charge.
On Tuesday of this week,facing a 20w panel at right angles to the low afternoon sun raised my battery bank voltage from 12.8v to 13.7v.... :D enough to allow my fridge to produce icecubes for my evening gin and mixed! :mad:
Post Fri Nov 18, 2011 11:29 am
The garage has windows on 2 sides, and see's a few hours of sunlight a day, so hopefully that'ss do the job over winter for the cab. :D
Topblag
Post Fri Nov 18, 2011 11:38 am
Even simpler, disconnect battery after use, if necessary, take into house and put on trickle charge. Aldi sold a charger recently for 13 quid, does the job just fine.
Solar chargers look interesting though.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
**BANNED**
Post Fri Nov 18, 2011 11:49 am
The point about the solar chargers is that they can never overcharge the battery,they have a blocking diode thingybob,so can be safely left attached all winter.
The panel it's self would be best placed in a window that faces the winter sun,or even plonked on the garage roof and wedged at a suitable angle,when the local cats investigate it,pick 'em off with your air rifle... winkeye
Only real snag is that they tend to be made of glass,so should be regarded as fragile.The type I use on the boat are stainless steel and fibreglass,so that they can be stood on,but these are very much more costly and require a charge controller to control their output.
Gert_8
Post Sat Nov 19, 2011 2:22 pm
Topblag wrote:Even simpler, disconnect battery after use, if necessary, take into house and put on trickle charge.
This is what I do while it's garaged
Over the winter.
