thermostat problem 88 or 71? M40 318i engine
markus_74
Post Thu Nov 17, 2011 8:54 am
hello,
from my thread before, that I suspect it as failed head gasket.
always had coolant loss and go to the mechanic said that my thermostat is sticking so it make my radiator leakage, because of the heat.
the problem is I always read at my temperature gauge and it never go halfway still cool enough, but the water come through the radiator leakage between the reservoir.
as I know before that sticking thermostat is always make temperature gauge go pass halfway, but it is not.
any idea?
also if I change my thermostat with 71 to replace original 88 what is the result?
thank you in advance
markus
Andyboy
Alpina Colada
Post Thu Nov 17, 2011 10:24 am
71 degree stat will just open earlier and maintain a cooler temp - not a bad scheme in a hot climate. In the UK you'd run an 88.
If the rad is leaking, the reservoir can be removed and the seal replaced. The fact thyat the rad is leaking means that the cooling system is losing pressure and thus running hotter. If it's on the original rad (not uncommon on an E30), a new rad would be a good idea anyway.
markus_74
Post Thu Nov 17, 2011 12:21 pm
does is it normal if the car move without AC temperature goes slightly below half and when stop with engine running it will stay at halfway?
and it the engine stop after trip and I just turn the key to acc the temperature goes pass half way?
