Seat recline issues
funge
Post Wed Nov 16, 2011 10:45 am
Hi Guys,
I am in the process of trying to figure out what is wrong with my drivers seat. If I try to recline it or adjust it the rear backrest wont fix back into place without a lot of fiddling around. It feels like it can find the teeth or is worn. Is there a guide to help me fix this or do I need a new part...... Your help is appriciated. Thanks
bimanut
Post Wed Nov 16, 2011 11:23 am
My brother had a simmilar problem.Take the back cover off the seat and check that the two big screws either side of the frame at the bottom corners are tight.One was practically hanging off and the other was a little loose,tightened them and problem was solved. 8)
Post Wed Nov 16, 2011 12:40 pm
As above, but if they have been loose for too long, the seat frame is likely to have cracked.
funge
Post Wed Nov 16, 2011 1:15 pm
ok guys, great advice thank you.
