I'm currently working on an M42 and on taking the plugs out i noticed the two nearest the front were caked in oil as were the ht leads.
Now the engine has had a rebuild at one point and a few of the rocker bolts are fooked and one i can pull straight out
Any chance this is why only two of the plugs were oily?
There are gaskets in each plug hole, where the cam cover joins the cylinder head, and oil will leak through here if all is not well.
The cure will be new gaskets and helicoiled bolts. http://bmwfans.info/parts/catalog/E30/2 ... ead_cover/
