central locking problem
jimbob29
Post Mon Nov 14, 2011 12:23 pm
can open and lock all doors via the boot!and if all locks are open i can close them on drivers side but once i open drivers side the others locks stay shut and the handel is hard to pull?i had a look inside door and everything seems a bit loose including the barrel but thers nothing around that area to tighten??could a clip or somthing have falling of down into the door??
Jim320i
E30 Zone News / COTM Team
Post Mon Nov 14, 2011 12:26 pm
On the back of the barrel should be a metal U shaped plate that slide over the back section holding the wired bracket in place too... First thing I would do is find this and replace it if it isnt there...
The barrel may well be moving just out of reach of turning the locks etc so start with that and report back.
jimbob29
Post Mon Nov 14, 2011 1:58 pm
just had another look and everythings ther but flops about and when i turn the key to open lock the barrel turns and that little coiled spring pops out of place.ive tried holding barrel and turning it but doesn't work :roll: the weird thing is if i push back the locking hook on side of door in the lock position with door open the locks work??? :?
Jim320i
Post Mon Nov 14, 2011 2:01 pm
Did you find the U plate part I mentioned? Is that attached as this will hold everything still... Also, check the tightness of the 3 crosshead screws or hex screws on the side of the door to make sure that part is held well too.
I have just had a similiar problem with mine which turned out to be to faults, but until you can get your barrell and everything holding still, i'd put it down to that.
jimbob29
Post Mon Nov 14, 2011 3:24 pm
u plate is ther and thers 2 holls either side with nothing in them?is it sopposed to have somthing in the holls?think ill take a look at passenger side see how it sopposed to be.is ther a link or diagram showing whats what??
Jim320i
Post Mon Nov 14, 2011 3:39 pm
The U plate part should hold the barrel in place aswell as another bracket that has part of the wiring attached to it... If its not there, fish it out and check how the other side sits for reference. I cant seem to locate it on real oem... But it sounds like this is your first issue atleast :mad:
jimbob29
Post Mon Nov 14, 2011 8:06 pm
still couldn't figure it out after looking at the other door lol so in the end i sprayed wd40 on the barrel and put a bit of metal behind it to stop excessive movement then worked the locks via the boot then tried the door!hey presto winkeye it bloody worked!!thanx jim..
