heavy steering
mdw
Post Sun Nov 13, 2011 5:20 pm
The other night i cooked the pas fluid and the steering get really heavy.
I changed the fluid and since then ive only done a couple hundred miles. However on the way home today the steering started getting heavy again when i checked the PAS fluid smells burnt again. My question is why does it keep cooking the fluid?
Post Sun Nov 13, 2011 9:07 pm
How many times did you change the fluid? You need to do it at least three times to get anywhere near all fresh fluid in the system.
e301988325i
Post Sun Nov 13, 2011 9:09 pm
have you got an E46 rack by any chance?
I said:
e30topless said:
lock the wife in there
mdw
Post Sun Nov 13, 2011 9:18 pm
Its a standard e30 rack.
I did flush the fluid a couple of times.
e301988325i
Post Sun Nov 13, 2011 9:25 pm
hmmm, after I fitted an E46 rack, my PAS cooked, and then kept doing it. I've no idea why it happens, possibly a blockage somewhere, i've never heard of it with a standard E30 rack, I cured mine by fitting a PAS oil cooler from an E46 320d, although I understand they're all the same, however a standard car shouldn't need the system changing.
I said:
mdw
Post Sat Dec 03, 2011 8:07 pm
car is still getting heavy steering, did it after driving for 20mins this evening. any ideas?
Post Sat Dec 03, 2011 8:12 pm
Maybe you have air in the system?
HairyScreech
Post Sat Dec 03, 2011 10:42 pm
pump problem?
Post Sun Dec 04, 2011 10:29 am
Maybe worth disconnecting the rod ends each side, and checking that you don't have a seized suspension joint.
mdw
Post Sun Dec 04, 2011 12:45 pm
i doubt its a sized joint as its fine when car is cold. its only after about 20mins it starts to get heavier. its still ok to drive just not as light as it should be
