uprated fuel pump / lights relay
E30LI
Post Fri Nov 11, 2011 2:38 pm
Hi guys,
Just needing some advice on a couple of things if anyone has a minute free...
I had an uprated fuel pump fitted to my E30 a bit back, but I've been told it's been fitted unsafe, and I had the same doubts at the time. Only twist is my e30 has an SR20DET conversion so the wiring is different to standard.
Basically, when i turn over the ignition it stays on constantly which surely isn't safe? I thought they were meant to start up then turn off after a few seconds. Also, it's wired using speaker cable direct from the ECU, through the centre console and then into the fuel pump, but it doesn't have any terminals, it's uses a choc block kinda thing straight into it which i've never come across before.
I took it to a professional garage because i wanted it done properly and safely, have they done that? The main thing i'm worried about is if the worst was to happen and i have a crash, the engine may turn off but the fuel pump would keep pumping fuel i'd have thought, which certainly isn't ideal.
Finally just a quick unrelated question, is there a relay under the dash that's for the lights?
Thanks a lot for any replies.
**BANNED**
Post Fri Nov 11, 2011 2:46 pm
As standard,the fuel pump will run constantly.The pump fills the fuel rail,then excess pressure is bled of via the FPR and returned to the tank,so that fuel is constantly circulating.I have no idea if this system is demanded by your current engine.
Most relays are mounted in the fuse box,with two or three in the engine bay,exact location depends on model.
There are also one or two,depending on spec,mounted behind the glovebox.One of these switches the power for the electric front windows/sunroof,the other,if fitted,controls the autobox start inhibit.
Youth is wasted on the young.
E30LI
Post Fri Nov 11, 2011 3:00 pm
Okay thanks for that. I was just checking because the standard 316i pump used to make the 'whizzing' noise for a few seconds and then go quiet (so i presume the sequence you mentioned above happens without being obvious).. this one sounds like it is constantly pulling fuel through and continues whizzing, which just seems a little odd and I'm sure i remember the person who fitted it saying not to leave the ignition on without starting it as it could flood the engine. But possibly this is what has to be done for the SR20 engine, i'll have to double check on the Nissan forums.
Cheers for the relay advice.
**BANNED**
Post Fri Nov 11, 2011 3:10 pm
As standard,the fuel pump is switched on when the ECU senses the engine is cranking,so in a collision,if the engine is stalled,the fuel supply is also cut.
E30LI
Post Fri Nov 11, 2011 3:44 pm
If mine is still meant to follow the same principles as the standard e30 one then i don't think mine is correct then, as mine starts and continues on just ignition, even when the engine isn't cranking. I will try and stall it later to check whether it carries on then as well. Thanks again for the reply.
E30LI
Post Sat Nov 12, 2011 12:02 am
Sorry to be a pain but can anyone confirm if there is a relay under the dash on a 1989 316i that would affect the headlights?
Someone is trying to charge me £120 for fixing a problem with my headlights, and their reasoning is that it was a hidden relay and the dash had to come out... i've checked as many wiring diagrams as i can find and can't see any relays for headlights under the dash...
I agreed to them doing it initially because it was meant to be a favour since they blew at their place, but now its been fixed apparently it was a lot of work to do so they want paying.. very 'professional'.
**BANNED**
Post Sat Nov 12, 2011 1:58 am
E30LI wrote:Sorry to be a pain but can anyone confirm if there is a relay under the dash on a 1989 316i that would affect the headlights?
Some-one is having their trousers tugged....
Post Sat Nov 12, 2011 10:35 am
There are no relays associated with the parking, number plate and dash lights.
There are relays in the fusebox (K3) for the main beam headlamps, and K4 for the dipped beams.
On models around '88, fitted with dim dip driving lamps (the dipped beams operate at half brightness with the sidelights and ignition on) there are two orange relays behind the front left corner of the glovebox that switch the dipped beams between half and full brightness.
Apart from changing the complete heater box and/or ducting, there are no jobs on an E30 that need the dash removed.
E30LI
Post Sat Nov 12, 2011 1:08 pm
Thanks for all the help guys, pretty obvious that they're trying it on with the lights then. And subsequently found that the fuel pump has been wired extremely wrong, and even worse dangerously. Thanks again.
Post Sat Nov 12, 2011 1:16 pm
Your fuel pump wiring sounds like it has potential for a possible fiery death! What kind of idiot does work like this?
If the ECU has no provision for fuel pump control, at the very least get an inertia switch (e.g. Ford, Peugot) into the circuit and/or connect the earth wire of the fuel pump relay to the oil pressure switch, with some arrangement to bypass it when starting.
E30LI
Post Sat Nov 12, 2011 4:31 pm
Yeah it certainly does, i've looked into it and with the sr20 the fuel pump usually runs from a relay which is switched by the ECU. Believe it or not both of the above were done by a 200sx specialist who did the full conversion. And i hate to say it but these don't seem to the worst problems i'm finding. I'm gonna give them a chance to explain before i name and shame but if not there will be a thread up very soon listing what i've found. Thanks for all the help above.
