diff refurb
hongkongfuey
- Mad-tango-geezer
How hard is it to refurb a diff, is it cost effective?
with cars like mine,
Brian28
Gareth can do it, how hard can it be?
Sorry Gareth
Depends on the car I guess (classic keeper or runaround), and whether its an LSD? I've never had an open diff refurbed, just stuck in another one from a breaker. Have had a couple of LSDs done by Gareth, definitely worth it imo if the car is a long termer and the ratio that you want.
hongkongfuey
- Mad-tango-geezer
Im keeping the car, i need a back plate for it anyway and will well the other one i have to fund it, just wondered if there is anything specific needed? Where is best to get the bearings and oil seals?
Brian28
Bearings and oil seals supplier - best to PM Gareth. Swapping the bearings and seals is relatively straightforward. Shimming to get the correct teeth mesh tolerance is the awkward bit, Ok if you're an engineer used to working with fine tolerances, but beyond my competence or knowhow. I found a couple of "how to's" via google, but rather than mebbe scrapping a decent diff through error I sent mine to the Diffmeister Gareth.
Andyboy
- Alpina Colada
If it's not leaking, make sure there's plenty of oil and just fit it. If it's noisy rebuild it, if it isn't, leave it alone.
randomspeedfreak
gareth can rebuild to some pretty special specs, im defo getting mine done by him...when i get one!
hongkongfuey
- Mad-tango-geezer
Its got leaks, just thought id do all while is on the floor
Andyboy
- Alpina Colada
New output shaft oil seals are about a tenner each from BMW and easy to fit with a big socket to drift them in with. Open diffs are not worth rebuilding more than that though.
gareth
Agreed. At present there are plenty of quiet open diffs around and the cost price of new bearings and seals will give you a few cheap open diffs to try.
LSD's on the other hand are worth looking after and are getting very rare in good condition. Once these get noisy they want attention quickly before it gets expensive.
Regular oil changes are key, but at the age of them, it's not 'us' that will have caused the damage, it's the previous owners!
