bushes/tightening up the drive
goldysingh
Post Wed Nov 09, 2011 7:23 am
Hi chaps
i am wanting to tighten up the drive of my car a little, feels slightly loose while driving at the moment.
I am wanting to change the bushes/rubbers onthe front end..
anyone shed somelight onto which bushed i should change?
The steering coupling would be the first..
any other joints/bushes?
many thanks
Mikey_Boy
Post Wed Nov 09, 2011 8:06 am
In short - as many as you can! :thumb:
Changing the steering guibo for a solid one is a good start for steering feel, but I would look at changing all the fron end bushes for poly bushes.
Also (and just as important) you need to change all the bushes at the REAR of the car as well - this more than contributes to a vague feeling when behind the wheel from unwanted rear wheel steering effects.
Good luck...
Post Wed Nov 09, 2011 8:28 am
If you want it driving properly you need to refresh the whole car - as a minimum at the front renew :
Droplinks
ARB bushes
"lollipop" bushes
New top mounts are a good idea too.
At the rear the beam bushes will almost certainly need doing - and if you're going to drop the beam off the car for any reason you need to do the trailing arm bushes whilst its off.
You can also do the rear droplinks, rear ARB bushes and Diff bush.
The best way to get it right is to do the lot but it ain't cheap.
ARB bushes front & rear, trailing arm and lollipop bushes are best bought dealer only
You can get lemforder beam bushes & droplinks from ECP
goldysingh
Post Wed Nov 09, 2011 8:30 am
thanks chaps
good thing i have a discount code for euro car parts, 30% off
