Propeller type noise.....
clipper
Post Mon Nov 07, 2011 7:43 pm
I hate threads about strange noises because it's impossible to describe them properly but I'm a bit worried:
At anything above 50 mph I hear a noise which could be best described as an airplane propeller (like when in an old film a prop plane is flying through a storm and the prop speed changes against the resistance).
i have experimented and discovered that it is not related to engine speed, but is related to road speed.
It seems to come from the front.
Applying the brakes does not cut the sound out (it just gets quieter until I reach about 50 mph then it can't be heard, the same as if I let it coast to slow down).
The car doesn't vibrate.
The brake calipers aren't sticking.
Cornering doesn't change the noise.
I am thinking that it could be related to the viscous fan (just because of the type of noise), but not really sure if it is a typical symptom of failure, the car does not overheat, not in traffic nor on the move.
Or possible wheel bearing ? Most threads about bearing noise describe "rumbles" or "whines", mine doesn't fit those descriptions.
Any ideas will be considered !
Post Mon Nov 07, 2011 7:45 pm
whip the front wheel off and check the backing plate isn't bent and rubbing on the disc,
mrb27
Post Mon Nov 07, 2011 7:47 pm
tyres? i had a 1 off tyre that made a strange noise like what you have described, might be worth checking out.
brucey
Post Mon Nov 07, 2011 8:08 pm
Possibly a piece of trim a bit loose and buffeting in the wind? Or not! How loud is it?
Ajsingh
Post Mon Nov 07, 2011 8:38 pm
Wheel bearing failure?
E30 Crazy!
clipper
Post Mon Nov 07, 2011 9:12 pm
@ Topless - Will do
@ Mrb27 -Tyres have been on for 2 yrs with no issues... but I'll give them a visual
@ brucey - I thought that but the frequency is too high, it's definately a spinning part
@ AJ Singh - It's possible (car is on over 1/4 million miles), but no vibes and no differece when cornering??
kman82
Post Mon Nov 07, 2011 9:51 pm
does it change if you are turning left or right?
clipper
Post Mon Nov 07, 2011 9:55 pm
clipper wrote: Cornering doesn't change the noise.
clipper wrote: no differece when cornering
kman82
Post Mon Nov 07, 2011 10:09 pm
:oops:
Post Mon Nov 07, 2011 10:18 pm
Is the fan catching the hoses?? or cowling??
clipper
Post Tue Nov 08, 2011 9:09 am
Rav335uk wrote:Is the fan catching the hoses?? or cowling??
I'll have looksee..
This morning coming to work I actually started to wonder if it was not coming from the center of the car more than from the front... the noise reminds me of the noise of the lift pump in the tank when I had the back seat out after replacing the pump.
Any chance it could be the dreaded diff whine? Or maybe another transmission issue?
mrLEE30
Post Tue Nov 08, 2011 9:47 am
At speed does noise remain with clutch in? In neutral at speed? This eliminates the fan as it should slow down with engine speed.
clipper
Post Tue Nov 08, 2011 12:07 pm
mrLEE30 wrote:At speed does noise remain with clutch in? In neutral at speed? This eliminates the fan as it should slow down with engine speed.
Noise is constant with road speed regardless of engine speed. i.e. with the clutch in and engine a tick over the noise is the same. Likewise if I put the car in neutreal and coast.
I have not (yet) tried turning off the engine completely at speed to see what happens (mainly because during the week I only drive in the dark and the headlights will go out if I kill the motor!)
This is why I'm beginning to think it may be transmission related... BUT does the fan not turn with the air movement of the car in motion?
lamby
Post Tue Nov 08, 2011 12:25 pm
air con fan,cover,might be spinning/catching with air pressure.
mrb27
Post Tue Nov 08, 2011 2:25 pm
try blocking off the air intake vents below the windscreen too, it could be somthin behind the dash, at speeds abovet 50 the wind will be quite strong flowing through the vents.
clipper
Post Tue Nov 08, 2011 7:53 pm
Latest news after a spirited drive home.... I lied earlier... twice..
The noise DOES go away on right hand bends. Wheel bearing ? Which side ?
Ajsingh
Post Tue Nov 08, 2011 8:31 pm
Ajsingh wrote:Wheel bearing failure?
Front right?
As its having the load taken off when going around a right hand bend, causing the sound to defuse
E30 Crazy!
clipper
Post Tue Nov 08, 2011 9:32 pm
Will get it up on the ramps tomorrow and have a look..
I've read that for fronts the best way to check is spin the wheel and feel for vibes through the spring... but on the rears ?
hazd31
Post Tue Nov 08, 2011 9:38 pm
i know it sounds stupid but is the wheel done up?
If not its probably wheel bearing, mine ended up being the opposite side to where it felt it was coming from!
kman82
Post Tue Nov 08, 2011 10:38 pm
e30topless wrote:whip the front wheel off and check the backing plate isn't bent and rubbing on the disc,
It could still be this. I bent the backing plate once and it only made a horrid noise when turning in one direction. Was at all speeds though.
From what i have read, bearing noises always get worse around the 50 /60 mark so that is most likely
EDIT:
hazd31 wrote:i know it sounds stupid but is the wheel done up?
I have also made this mistake!! :o:
mrLEE30
Post Wed Nov 09, 2011 4:02 pm
Almost impossible to guess what side wheel bearing, even using AJ Singh's logic, it could be argued that more load on right when cornering right, but left wheel also experiences a load change when going right. Best bet is to change the pair - and even then it could be the rear.
I changed my wheel bearings on my 540 after certain it was the bearings, did both, drove out garage and no change, whub whub whub noise. Turned out to be my 5000km old Pirelli p zeros. So my advice before you pull bearings out is a free swap of your wheels, move all four diagonally accros the car, see if noise changes. If so then maybe tyres are the source.
Ajsingh
Post Wed Nov 09, 2011 4:04 pm
^^ lol do them both!
E30 Crazy!
clipper
Post Wed Nov 09, 2011 8:04 pm
Any problems putting ABS hubs/bearings on a non ABS car?
All the aftermarket stuff I can find is for ABS...
Post Wed Nov 09, 2011 8:08 pm
No problem, the abs ring can be removed if need be, or were on the last ones I did.
clipper
Post Sun Nov 13, 2011 12:19 am
Rav335uk wrote:No problem, the abs ring can be removed if need be, or were on the last ones I did.
Cheers for the replies. Confimed wheel bearing after all.....
