hi all
Got a bit of an issue with my 2.5 m20. I keep on getting air lock in the water system, ive changed the thermostat, heater valve and matrix. bled the system, made sure there is no air in it, ran the car for 30 min with good water circulation. I can drive the car around no problems heating and everything good. I leave the car parked overnight, and in the morning i would get air in the water system. how i know, the car would warm up quicker than it should and the blowers would blow cold air some times if i rev the car i can hear the water circulate and the heaters would blow out warm air then hot and the temp needle would come down. not sure what it could be the only thing i can think of is possibly head gasket?
Any suggestions i dont really want to spend big money on this engine as i'm planning to m52 it in aba 6 months.
ta Kam
air lock problem!
kam325itouring
All Car Audio - Approved Alarms - HID Kits - Custom Boot Installs - All jobs considered
blingsta
- Boost Junkie
did you connect the matrix hoses the right way around? try swopping them over
Bleeding only needs to be done once. Once it's done it's done, so if you are getting more air/gas in there after you've removed it, it can only be combustion gasses from a cylinder.
Corrosion of the crescent shaped waterways in the head is a favourite on M20s - they corrode back under the head gasket fire rings.
kam325itouring
matrix hoses are the right way round. looking more towards gasket. gonna investigate it a bit further.
