Were all E30's fitted with ABS?
alexdejonghe
Sorry for the uninteresting question chaps, but Kwik Fit need to know so as to fit the correct rear wheel bearings...
From a quick Google search, the Bimmer forum told me that all cars after 1985 WERE fitted with ABS...sound about right?
Mine's a 1989 318i...lovingly kept!
maxfield
Nope, not all E30's were fitted with ABS.
pac1982
Nope my 1990 318is did not have ABS
ABS is for pussys any way
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
- **BANNED**
You will probably find that all rear hubs are equipped for ABS,but not all cars are fitted with the sensors and ABS operating gear.
I have a touring,with ABS,and a cabbie without ABS,both,of course,have rear disc's,and I would expect that the same hub/bearing unit will fit both.
Youth is wasted on the young.
pnd
i think all 325's had it after 1987 don't know about other cars. My 1986 325 sport without abs had the firmest feeling and best stopping brakes i have experienced on an e30.
the bearings are the same on all "disc" trailing arms, the ABS pick-up ring is on the drive shaft,
- **BANNED**
And ABS was only fitted to rear disc spec'ed cars,correct?e30topless wrote:the bearings are the same on all "disc" trailing arms, the ABS pick-up ring is on the drive shaft,
TPS
I've been spoiled, Both mine are Tourings, & both have ABS.
More to the point, why are you letting Kwik Fit loose on your car?
Grrrmachine
- E30 Zone Wiki / Team Member
That was my first thought when I read the post...Brianmoooore wrote:More to the point, why are you letting Kwik Fit loose on your car?
groovylee
indeed, don't let them do it, bunch of fookin cowboys. words cannot describe the levels of incompetence that have been seen at Krap Fick branches...........
1989 320i Cab for sale - http://www.e30zone.net/modules.php?name ... highlight=
alexdejonghe
...hmm, it might sound odd to say, but those scousers down the road at Kwik Fit aren't THAT AWFUL when it comes to regular service items (such as tracking rod ends, wheel bearings etc.)....and they're always complimentary about the old girl!
As for ABS, i had a nose about, turned on the ignition and BINGO, an ABS light came on!
Topblag
+1. Find somewhere where they have experience of working on E30s and won't advise you that you need to change parts that are actually fine.Brianmoooore wrote:More to the point, why are you letting Kwik Fit loose on your car?
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
alexdejonghe
Duly noted!
