Fan not kicking in when engine gets hot.
fender182
Post Fri Nov 04, 2011 5:20 pm
as title says, noticed the engine temp got a little high the other night and when I pulled over the fan hadn't kicked in. It usually turns on when then temp gauge reads above mid. possible problems?
M42 with electric fan.
Cheers,
jamie
2.1 318iS E30 - Weekend toy (2.8 loading...)
330Ci M Sport E46 - Work horse
335i M Sport F30 - Family car
mrb27
Post Fri Nov 04, 2011 9:25 pm
fuse and relay is first port of call, if they are ok check the fan switch, you should be able to bridge the 2 terminals on the switch to make the fan kick in, if the fan kicks in then you have a bad switch on your hands. if the fan does not kick in but you hear the relay click then the problem will be from the relay power output to the fan 'possibly the fan' if fuse/relay/switch are ok then you move onto wire connections or fan itself. clean up any connections then test the system by buypassing the switch again, hope that makes sense as ive alredy had a few to drink :mad:
Billwill
Post Sat Nov 05, 2011 10:58 am
There is normally a two-stage thermal switch on the radiator. There are three connections on it...the centre one carries +12 volts and is the centre position of the thermo-switch.
As the temp gets up to 90 deg C, the one contact makes and connects the +12 volts to the low-speed circuitry to drive the fan at low speed. When temp gets to 99 deg C the other contact makes and sends +12 volts to the high speed circuitry.
You can test the switch is working by connecting an Ohm-meter to the switch contacts and heat up the switch with a hairdryer or heat gun...dont melt any plastic bits!....first the one contact will close and then the other one closes.
With ignition ON..measure the one pin to see which on has +12 volts on it...then jumper that wire to one of the other pins...one should spin the fan slow while the other will spin it fast.
The above definitely applies to the M40 with air-conditioning....may be some differences with your model. :)
