lsd questions
elijah318is
im looking to get an lsd for my e30 . I have found one im going to check out tonite. It is out of the car so is there any way of checking it out for wear other than looking for chatter marks on the teeth. Also am i right in thinking that if its a 4.1 ratio 4 turnes on the input is 1 turn on the output
- **BANNED**
On an open diff,turning one output shaft causes the other one to turn in the opposite direction.
On an LSD,both outputs should turn the same way,and it should be difficult to stop one turning.
Youth is wasted on the young.
