VW Golf MK1 Cabby
rh306
Post Wed Oct 26, 2011 9:59 pm
Are these any good? Seem to be worth virtually nothing on ebay at the moment :)
http://www.ebay.co.uk/itm/1985-golf-mk1 ... _500wt_949
320Touring
Post Wed Oct 26, 2011 10:15 pm
THey can be, My Mrs has one..
Currently tearing my hair out trying to get parts correct for it..
they are damn cool though, and parts not too bad price wise..
the Gti is the one to have though.
Post Thu Oct 27, 2011 8:46 am
They rot worse than an E30
Fuel filler necks commonly rot out and contaminate the fuel system.
if you get a manual one the Clutch cable mounting in the bulkhead is a common weak spot - not just for rot - the metal is too thin so the cable mount actually pulls through the bulkhead. Needs a reinforcing plate welded in and its a bit tricky to get at.
a 1.6 Auto will be a slug.
As above if you get one the GTi is the one to go for
320Touring
Post Thu Oct 27, 2011 11:43 am
capri_rob wrote:They rot worse than an E30
ditto on the clutch cable section..
It was not fun to weld.
We bought one that was great bodily..now to sort suspension etc :cry:
rh306
Post Thu Oct 27, 2011 12:40 pm
thanks, tread carefully by the sound of things, :o
