Just wiring up all the leads for the m42 318is.... However i don't know the order they go in, and where each one plugs into on the coilpack.
As well as this, i dont know where the 4 plugs go which plug into the coilpack unit. As in, the orders etc.
my leads have 1,2,3,4 written on them. I suppose the longer leads are closer to the front of the engine.
Please can someone help me on this with pictures or a diagram or something.
m42 ignition leads
redcar
This is really helpful:
Found it from this website: http://tis.spaghetticoder.org/s/view.pl?2/04/56
still don't know the order of plugs from wiring loom going into the coilpacks
rix313
They should only be able to go one way due to the way they are wrapped and heat shrunk together,
redcar
are you referring to the engine loom to coilpack connection?rix313 wrote:They should only be able to go one way due to the way they are wrapped and heat shrunk together,
rix313
