dumb thing to do
red50x
Post Tue Oct 25, 2011 1:26 pm
at weekend i fitted spacers to the rear wheels and used overlong studs to attach . The car was on an incline and rolled back off the jack back making a nasty noise at the hubs . I think the overlong studs must have hit something on the inside
I hastily re jacked the car and removed spacer and refitted the wheels using original studs . My test drive after revealed a strange but regular noise coming from the rear hub as the wheels rotated
any ideas what i could have damaged ?
gcs325i
Post Tue Oct 25, 2011 1:35 pm
Possibly damaged the rear shoe mounting pins by ripping them of the back plates or just moved the shoes so that they are binding a bit. Is it rear drums or discs?
Post Tue Oct 25, 2011 2:11 pm
^ A rear disc-braked E30 will also have drum brake linings in the hub for the handbrake.
So yes, you will most likely have upset the drum shoes. You'll need to remove the drums/discs to find out what's what.
red50x
Post Wed Oct 26, 2011 12:27 pm
thanks much for your advice , I will check at weekend
Post Wed Oct 26, 2011 1:56 pm
red50x wrote:thanks much for your advice , I will check at weekend
Don't use the car in the meantime!
