Intermittent wiper setting not working
cee
As title. Any ideas?
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
Most likely to be the wiper motor needing a refurb.
There is an article in the wiki which tells you how to do it step by step.
DHFiS
cee
Yes all other settings work, and thanks, will check the article
greg124
I stripped, cleaned and rebuilt the wiper motors on both our cars, as per the article in the Wiki mentioned above. First one took about an hour, second rather less. Both now work perfectly.
Not difficult, and well worth doing IMO
Schadenfreude - the German's haven't got a word for that.
Billwill
If the other settings ie. slow and fast are working as stated and if the wipers return to the Park position as it should....then I do not believe that the problem is with the wiper motor/dirty motor contacts as that Wiki link proposes.
If it is purely the intermittant function that is not working then I believe that the problem is with the wiper switch or more likely with the wash/wipe interval control unit which is K10 in the power distribution box.
By all means do the Wiki wiper repair procedure first.....that area does suffer from bad contacts from all the grease and grime there...if that does not work then check K10 and the wiper switch.
cee
Oh, it doesn't automatically return
Billwill
cee wrote:Oh, it doesn't automatically return
OK then definitely do as advised and follow the Wiki link on how to clean up the wiper motor assembly.
If you have the later face-lift models...the procedure is a bit easier as the wiper motor lifts straight up and out
cee
Sounds good, but confused as to the chances of both motors being faulty at the same time?
Billwill
cee wrote:Sounds good, but confused as to the chances of both motors being faulty at the same time?
There is only one motor for the front....wipers are connected by a linkage. If you have a Touring then you would have a motor at the rear.
After you have cleaned up the motor and fitted it back in place...initially do not fit the actual wipers. Run the motor and let it return to its "park" position. Now fit the wipers in place...out of the way... and bolt them down.
cee
ahh I see, makes more sense now. Thanks
