turbo injectors
scottyc
Post Tue Oct 18, 2011 10:55 pm
Hi looking for some advise on injectors for a 2.7 turbo m20 project!
after reading alot of info does anyone have any advise on what injectors can be used?
high impedance! and from what i read need to be at least 350cc as the stock ones are only 147cc!
just wondered if anyone had come across a car with stock injectors that would fit and be big enough!
anyone use sabb 900 turbo ones?
what injectors are people using on stock motronic? and on after market?
i want to try and keep motronic for now but am shooting for 300-350 hp
Gunni
Post Thu Oct 20, 2011 10:16 pm
Audi 5cyl ones are 315cc I think,
i have used them before to about 260hp. You´ll need at least 32lbs injectors for 350hp .I´d reccomend 42lbs
Gunni
@ 2012 VEMS group buy !!
b12rlw
Post Fri Oct 21, 2011 10:24 am
I got my 440cc lime greens and walbro pump
From cts turbo in California. Postage was around £40 if I remember correctly. Check their website.
DmcL
Post Fri Oct 21, 2011 6:19 pm
volvo T5 injectors (+1) will work for 8psi and then some.. they work out at 30lb/hr which is 315cc. i tuned an 8psi setup on these injectors and there was definately room for more boost before having to fit larger injectors. im planning on running similar size injectors for my own turbo M20 that im collecting parts for at the moment.
WMMotorsports
ross2009
Post Fri Oct 21, 2011 10:40 pm
im with gunni at least 42lbs america is your best bet coz they run then in injected small blocks
some thing like these
http://www.ebay.co.uk/itm/BOSCH-0280155 ... 3f09a23e1e
Turbo M20
v8 project 6.0 twin turbo
scottyc
Post Mon Oct 24, 2011 2:27 pm
hi dmcl, im the lad who has been talking to you through ebay about mapping! :D
i have decided to use mini cooper s ones as i have 4 knocking around at work, and can get another set for £25. there 330cc
scottyc
Post Tue Oct 25, 2011 10:32 pm
think your find t5 injectors are
FLOW RATE
lbs/hr 33.3
cc/min 350.0
grams/min 251.7
Rating @
PSI 43.5
BARS 3.00
.42 BSFC - Est. HPDuty Cycle (80%) 63.4
.52 BSFC - Est. HP Duty Cycle (95%) 60.8
Impedance HIGH
TheMeathead
Post Wed Oct 26, 2011 12:57 pm
The volvo injectors come in three types as standard
orange ones : 315cc at 3bar
white ones : 350cc at 3bar
and blue ones : 350cc at 3bar and 395cc at 3.8bar
the white ones aren't very reliable and can fail as ive been told.
DmcL
Post Wed Oct 26, 2011 11:29 pm
anything over 300cc should be sufficient for atleast 8-10psi at a minimum id think. as meathead says there are different T5 injectors, discovered that after i bought 1 set which i still have sitting here as i need 1 more to make a set of 6. the ones i mapped the 8psi car on were the same part number as the T5 ones i have but they came from a 6 cylinder S80 of some sort so was a complete set of 6 to begin with.
dont forget if your running out of room for adjustment in fuel maps you can always chuck in an adjustable regulator and bump the fuel pressure over 3 bar to save having to buy a new set of injectors.
also a bit of random info u might find useful.. 6 cylinder S80 fuel rail has identical injector spacing as M20 rail but isnt a return fuel system. also M50 rail has the same injector spacing as the M20 and is a return system and some if not all of the M50 rails have a 3.5 bar regulator as standard. i may actually have an M50 rail around here somewhere if i didnt toss it or something. still have the S80 rail which is alloy, could maybe be drilled/tapped or whatever to convert it to a return style rail and tarted up to look all pretty.. actually thats not a bad idea there :idea:
WMMotorsports
