Clutch master/slave cylinders
Rallyprep_UK
formerly Driftnething
Post Mon Oct 17, 2011 11:00 pm
Are there any different versions of the clutch master ? I have a 316i with an m52b28 and the clutch is a brand new 2.5 m20 item. The flywheel is also m20 obviously.
The only thing is that the bite is very high (right at the top). I think from memory I have used the e36 328 slave cyl but cannot be sure as I had bits everywhere lol...
Has anybody else experienced anything similar ?!
Will
Racing is living, everything else is just waiting...
http://www.rallyprep.co.uk
**BANNED**
Post Tue Oct 18, 2011 9:33 am
All E30 clutch operating bits are same across the range,no idea if E36 bits are the same!
You have bled the thing properly,of course?
Youth is wasted on the young.
Rallyprep_UK
Post Tue Oct 18, 2011 10:26 am
Lol yes it's bled properly :-) I think I will try and fit a new e30 slave
blue30
Post Tue Oct 18, 2011 9:58 pm
Some of the M50 slaves have a slightly larger piston, I think 22.5 rather than 20mm? Anyway I got one of those on mine and it helped a little bit. That was replacing a 20mm M20 slave with extended rod with the 22.5mm M50 one. HTH.
Rallyprep_UK
Post Tue Oct 18, 2011 9:59 pm
ahh good :cool:
thanks mate :P
