Hi
Just putting on a new front wheel bearing. There is a red stip between the inner and outer race at the back by the abs ring. Does anyone know if this needs removing? its a febi bearing if thats any help...
I just ask as i've found some tech articles on replacing the bearing that say there is a temporary nylon piece that holds the two bearing parts together.
cheers
front wheel bearing fitment
Chimmychanga
Chimmychanga
I've put it on now. The old bearing had one, I could tell once I cleaned it up a bit. So its back on and all is good.
