Need some advice please zoners. My car is running a E30 M3 brake setup but still retains the 325i master cylinder.
Therefore when i brake the pedal can take a while to return and the brakes stick on.
The correct solution is an E30 M3 master cylinder although this is coming in rather expensive at circa £500.00
C3BMW offer this
However as my car doesn't run ABS they mentioned about joining brake pipes which sounds hard work and they said its not really suitable for an every day car
Does this then mean that even the BMW M3 cylinder will need brake pipes joining as M3's run abs?
Any other alternatives?
M3 Master Cylinder
SteSE
- Heading for the Naughty Room
SteSE
Sorted -a T piece is the answer
Props to C3BMW and ETA motorsport
