I bought a set of front calipers and disks from a user here to convert my solid fronts to vented.
The issue is that the calipers i received for the front. One is a girling the other is an ate. Will they perform the same or will i have braking issues? pulling to one side maybe?
Ps i am going to change the seals.
front calipers different
Jozi
Measure the piston diameter, they should both be the same. I'd be happier with 2 of the same callipers though!
- **BANNED**
Most car makers have more than one supplier for components,the calipers SHOULD be the same spec,but like Jozi,I would be happier with a pair the same make!
One option would be to offer your odd pair up for exchange with a national factor such as Unipart(Partco)...and plead ignorance if the guy on the counter spots the difference....
Youth is wasted on the young.
balilu91
piston diameter is the same .. I checked some places and i couldn't find an other ATE Caliper.. btw im not from the UK or anywhere near..
The only ones i found were Girling (for about 35 Euros) and i dont know why but i took a liking to the ATE ones.. I have to either get a girling or I leave them one ate & the other girling..
still undecided tough.. it seems it would be a waste of money and i dont really have my pockets full right now..
thanks for your help
e301988325i
I don't think you'll notice the difference. If one of a fitted matching set was replaced by a garage they wouldn't even think about it. Put your OCD to bed.
I said:
e30topless said:
lock the wife in there
