LSD Help
mzmz
Mon Feb 07, 2005 3:43 pm
right ive got a 325i cab, which was an auto but had it converted to manual
now i cant get the car to donut properly
and mates tell me that only one wheel is spinning when doing a burnout etc.....
is this becuase of the standard diff
what do i need a sport LSD or something and if yes what differences will i be seeing will there be a difference in power???
and will i definatley be able to donut it?
all feedback shall be appreciated
thanks
p.s which lsd do i need which ratio??
Simon
Mon Feb 07, 2005 4:05 pm
With an LSD you will be able to doughnut properly.
The LSD limits the amount that a wheel spins, it will lock the diff depending on the rate, hence the reason only one of your wheels is spinning.
mzmz
Mon Feb 07, 2005 4:26 pm
so which one do i need?
3.64 is that the one
also how hard is it to fit, basically how much would it cost to fit
ScottMc
Mon Feb 07, 2005 4:29 pm
i have an LSD for sale mate! PM me for more info! :D its not too difficult to fit either.
gone but not forgotten - Mtech 1 old skool 325i :: current rides- MR2 GT and 318i Touring Image
Mon Feb 07, 2005 7:05 pm
the most common althought both rare is 3.64 and 3.91, or the best comprimise is a 3.7 something but do these exist in LSD form?
Diff fitting is not too bad a job, re-fitting can be a bit fiddlely but if you're not a complete spastic with a spanner then you should be ok
E30Adam
Mon Feb 07, 2005 8:14 pm
Simon13 wrote:the most common althought both rare is 3.64 and 3.91, or the best comprimise is a 3.7 something but do these exist in LSD form?
You can get a 3.73 LSD although quite rare.
What's the point in doughnutting anyway, you jut stress out everything and wreck your tyres. It's just as bas as wheelspinds and handbrake turns. Try drifting then you might impress someone.
