What management / ecu did you use?
Custom loom or just 2.8 engine harness?
Are these parts a direct fit or what machining is required?
How good are the std 2.8 pistons in terms of taking boost pressure?
Is the M52 head better than the M50 one?
Basically long term plans are to turbo my M50 lump, it could do with a bit of a refresh as it is a highish mileage engine. In the future I will be running VEMS or possibly re-worked stock ECU.
For now though it will stay N/A. The engine isnt going in a bimmer either
Input from anyone thats done it would be appreciated.
Thanks,
Ed
