so got a 316i auto, when the engine is idling it will eventually make a noise like air is being sucked in and then dies, i've put the idle up to 2500 and it doesnt die, but if i let it idle at the normal level it dies.
checked the tps, and checked for air leaks there are none.
any ideas?
316i m40 auto dies at idle
groovylee
idle control valve? sorry, not too hot on the 4 pot engines
What happens if you set the idle to 800 RPM?
I hope you haven't been playing with the throttle stop, or at least know exactly where it was set. It was set at the correct point at the factory, using a special tool, and NEVER needs adjusting.
In spite of what you say, it sounds like air leaks and/or TPS to me.
Billwill
If you have moved in the throttle stop...normaly has paint on when it is factory set as Brianmoooore has stated.....you need to wind it out again until you hear the TPS microswitch under the intake manifold "click". This tells the ECU that the throttle is closed....you may have to measure the switch to see that the contact is closed. Then do not ever adjust this screw again....also check that the throttle cable is not too tight which stops the throttle from returning home properly. If you cannot get that switch to "click" then you may have to adjust its position via its two mounting screws...difficult to get to as it is under the manifold.
Now remove the ICV valve which is the silver cylinder plugged into the underside of the intake manifold....next to the battery. It plugs into a rubber grommet in the manifold and you have to remove the electrical connector and the hose that's attached.
Give this valve a good clean with petrol and spray some Q40 or whatever into it for lubrication.
You can test that the valve opens and closes by briefly touching twelve volts across it but do not leave 12 volts on it. This ICV normally gets pulsed DC from the ECU to open it the correct amount.
Unless you also have air leaks somewhere then it should work....I have to clean my ICV valve about every 6 months or the idle is bad.
