speedo, mpg swing thing and mileage stopped working
bm_guy
Post Thu Oct 06, 2011 3:23 pm
Hi,
I started my car after a while, turns out that the speedo, mpg swing thing and mileage have stopped working. I have tried a different working speedo, but no luck.
The car has been converted from a 318 to 325 before, worked okay before.
Please help as the car needs a mot in 4 days!
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Oct 06, 2011 3:44 pm
gudgeon
Post Thu Oct 06, 2011 3:50 pm
Almost certainly the switch in the diff no?
beemerbird
Post Thu Oct 06, 2011 7:21 pm
I don't believe that a working speedo is an MOT requirement? May be wrong, though . . . . . . .
Post Thu Oct 06, 2011 7:25 pm
The car will be unroadworthy without a working speedo, but it won't be a reason for MOT test failure.
bm_guy
Post Thu Oct 06, 2011 9:05 pm
I will change the switch tomorrow and report back.
MOT failure or not, would be nice to know how fast im going.
Thanks guys
Post Thu Oct 06, 2011 11:25 pm
Unlikely to be anything wrong with the sensor in the diff. The usual problem is with the wiring to the sensor which deteriorates as a result of vibration from the diff.
The wire (last 300mm, including the plug) must be replaced, not repaired.
bm_guy
Post Fri Oct 07, 2011 5:00 pm
Where can i get the plug from?
I ordered the sensor from eurocarparts but. they were not sure if it comes with it.
Anyone got a part number?
Post Fri Oct 07, 2011 6:30 pm
If it helps, the plugs are the same has headlight plugs (well they are on the later post 88 cars) So if you have access to a breaker, raping some headlight wiring would be the way to go
Post Fri Oct 07, 2011 6:32 pm
Plug doesn't come with the sensor, and I very much doubt you need a sensor anyway. They rarely fail.
Repair lead is available from BMW, but most people use a plug and lead from an E30 headlamp, which is identical. The lead here doesn't suffer from deterioration from vibration, so a second hand one is fine.
groovylee
Post Fri Oct 07, 2011 7:08 pm
agree with all of the above, but i would say that although the sensor rarely fails, it does fail occasionally, as i found out after faffing with the wiring for half a day and finding nothing wrong....... :lol:
