I purchased a car earlier today, I was told it had a LSD, I jacked it up and both wheels span, so took the owners word for it.
After taking a mate out for a ride, he thinks it maybe a welded diff. because of a clunking noise at the rear when parrell parking or reversing into a bay.
Whats the best way of checking? Other than on the tag, (I dont think it has one).
Do i have a LSD or welded diff
hazd31
Jack one rear wheel off the ground, put a chock under the front wheel, take the handbreak off and take it out of gear, if the wheel wont turn its welded. if its heavy to turn then maybe an lsd
leeparkes
This ^ with a good grip you will be able to turn the wheel if its LSD, a welded will try to pull it off the jack so be carefull.hazd31 wrote:Jack one rear wheel off the ground, put a chock under the front wheel, take the handbreak off and take it out of gear, if the wheel wont turn its welded. if its heavy to turn then maybe an lsd
Barx325i
leeparkes wrote:This ^ with a good grip you will be able to turn the wheel if its LSD, a welded will try to pull it off the jack so be carefull.hazd31 wrote:Jack one rear wheel off the ground, put a chock under the front wheel, take the handbreak off and take it out of gear, if the wheel wont turn its welded. if its heavy to turn then maybe an lsd
or if you don't have the balls to try yanking it off its jack it should be immediately apparent if it's welded, just consider the tiny amount of play and the 'thunk' which the clutch packs will give you.. if it's a resistant yet reserved thunk it's likely to be an LSD, due the inertia of the extra 'business' in there if it's lightweight metallic clank, it's welded cogs
Green
If it's welded, usually when parking or turning around tight corners at slow speeds (ie car parks) you'll hear one wheel being dragged along.
sheebie
Did this turns out it was hard to turn, when both back tyres are in the air they both turn. Looks like it is an LSD, so happy days.hazd31 wrote:Jack one rear wheel off the ground, put a chock under the front wheel, take the handbreak off and take it out of gear, if the wheel wont turn its welded. if its heavy to turn then maybe an lsd
Now need to find out what ratio...
hazd31
to find the ratio, jack both wheels off, spin them one complete rotation and count how many times the prop turns. Basic but effective.
