please help
damian666
Hi i have a e30 325i soft top. i have replaced the fuel pump and relay. the injectors are getting fuel and spraying once when u try to crank it. but then stops so the the car wont start anyone have any ideas? thanks
Barx325i
maybe it's cursed?
beemerbird
Fuel filter?
TPS
Fuel pump Relay?
Jim320i
- E30 Zone News / COTM Team
Grrrmachine
- E30 Zone Wiki / Team Member
Are you definitely getting spark?
cecotto479
- Caution Unreliable Seller
Pre facelift?
The ECU controls the fuel pump while the engine is cranking and once it starts the speed sensor keeps it going. No input from the speed sensor kills the fuel pump.
If it fires up then dies, the speed sensor is definitely worth a look.
It's not the reference sensor - it controls ignition.
1981 E23 735i
damian666
i know its not the fuel pump or relay. wile i crank it the ful pump is still pumpint but the injectors are not spraying.
