Hi everyone,
I recently purchase a set of E30 electric windows of ebay the seller claimed he bought them from the US for his 325 coupe but no longer needed them as he sold his car. I bought them for my 323i, since then i have removed my driving door card and tried to fit them or atleast see where they mount and so i quickly became quite confused as to how. I have since found other ebay listings in the US which pictures match but say they are for a 4 door. what do you think?
http://www.ebay.com.au/itm/110745811799 ... 500wt_1156
E30 Coupe Electric Windows
poolnoodle
The kit in the eBay ad is for update mechanism - scissor lift type.
E30s have two types of window lifts, not sure when they changed over.
I did this conversion to my '83 323i and it was dead simple...if you have the right parts.
You need the mechanism from an earlier model and it is a direct swap for manual mechanism - looks almost the same but with the motor.
On sell these ones (make it clear that they are for a later E30 model) and source an early mechanism. They shouldn't be too hard to find at wreckers.
I have some pics somewhere, will post if I can find them.
poolnoodle
Here is a thread with some instructions:
http://www.e30zone.net/modules.php?name ... +mechanism
This link shows the correct mechanism for your 323i:
http://www.realoem.com/bmw/showparts.do ... g=51&fg=10
This is the type of thing you need:
http://www.ebay.com.au/itm/BMW-E30-Used ... 336c6295db
Hope this helps.
Hope this helps.
djsimmy
sorry to hijack thread if mine is an 86 tech 1 will i need the old 1 in pic 2?
poolnoodle
Not exactly sure when the change was - probably best to whip off the door trim and make sure
djsimmy
its allready off. doesnt look like a big scisor cant see much cos ammount of metal tho
greggers
If anyone in the UK wants to do a straight swap of manual window parts for my electric window parts, please let me know, my car is a pre-facelift coupé, so your car will also need to be a pre-facelift coupé I believe.
