lost all right indicators
mineralblue
Rocking Horse Poo
Post Mon Oct 03, 2011 11:08 am
Morning gents, as title, think it's indicator stalk related. Could sometimes get them to work, now they have stopped. Clicking double fast like a bulb has gone but all bulbs ok and hazards work fine. Does the switch gear fail on these or could it be a loose wire? left hand work fine as does full beam.
Thanks in advance
Morgan
KimH
Post Wed Oct 05, 2011 10:21 pm
I had exactly this with my 1991 Touring and it turned out to be a loose connector deep in the dash.
I swapped out the indicator switch without affecting the symptom and, with the clocks out, traced the wires to find another connector deeper into the dash wiring loom - reseating this some 3 years ago solved the problem and it has not returned.
Good luck.
DHFiS
Post Thu Oct 06, 2011 8:27 pm
The switch can fail, I had to swap mine.
