will the rx7 calipers go under 15 inch wheels?
punko
Post Sat Oct 01, 2011 6:19 pm
as above ill buy some if they will go under my 15's???
turk
Post Sat Oct 01, 2011 6:46 pm
you'll be very tight... depends which alloys u use? I have lenso 16's and they are tight too, still needed 15mm spacer
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
DHFiS
Post Sun Oct 02, 2011 12:28 am
Not without spacers to move the wheel away from the caliper. If you use spacers with 205/55 tyres you will need to roll the arches so they dont rub.
