Starter motor differences
E30_Crazy
Post Sat Oct 01, 2011 9:53 am
Thought I remember reading somewhere that pre-facelift starter motors are different than facelift ones. I've got a facelift motor without a starter motor going in to replace my pre-face one, and was wondering if I can use my pre-face starter?
gooner1
Out humping Reindeer
Post Sat Oct 01, 2011 10:04 am
If you check the build year on this lot, you should get your answer.
http://www.realoem.com/bmw/partxref.do? ... series=E30
E30_Crazy
Post Sat Oct 01, 2011 10:18 am
Hmm.... It's showing that the change occured 12/1986. My current starter is in a 1/1987 car. I think it's just the electricals of it that are different (for the different engine managements) but I don't want to get the motor all in, and then the starter blow up or not work. Not sure if one can replace the starter in situ or not.
E30_Crazy
Post Sat Oct 01, 2011 11:22 am
Think I might have spotted something. The pre-face starter only has 2 wires going to it, obviously a + and ground. But on the facelift engine at the starter location there are 3 wires.
I've been doing some searching online but can't seem to find anything relevant to this. Gonna head to the scrap yard and see if there are any E30's laying about. Might need to nick the coolant system off of it too.
**BANNED**
Post Sat Oct 01, 2011 11:30 am
Swapping the starter on an M20 is dead easy with the engine'/box on the garage floor,but a proper bugger with the engine in the car.Not impossible,but you will be teaching your niegbours kids a lot of new words!
My facelift M20 certainly has three wires,all the fasteners are different sizes so it's next to impossible to wire it wrongly,really,you need the correct loom for the engine.
Youth is wasted on the young.
Billwill
Post Sat Oct 01, 2011 12:02 pm
The extra wire (Black/green) on the starter is normaly for the unloader relays K5 and K7 to drop power to the aircon, heated seats and mirrors as the starter engages. This is how the newer motors work, I am not sure if the older models have the same system but it should not be a showstopper to fit the new starter. :?
gooner1
Post Sat Oct 01, 2011 12:51 pm
E30_Crazy
Post Sat Oct 01, 2011 3:09 pm
Crap, well, there's a free £30 to the scrappers for the starter... I'll still have a look at my pre-face and see which one is better condition, and use it.
Oh well. It's progress I guess. Now my only concern is cooling system. I don't have a facelift rad or expansion tank, so I'm gonna see if I can mix-and-match some hoses and see if I can keep the pre-face tank and rad. Mainly for era-correct-ness (Being a Tech 1)
E30_Crazy
Post Sun Oct 09, 2011 7:42 pm
Well, the starter motor from the scrappers was a no-go. Got the engine in and everything piped and routed. Ended up going with the FL rad and tank (Thanks Ross!). We tried starting it up, but the starter just whirls aways without cranking the engine over. So, now I have the pleasure of changing it with the engine in :x . We did roll start it, however, while towing it to it's parking spot at the shop. Straight out of the headers, and a lopey 288 cam sounds pretty mean :twisted: .
E30_Crazy
Post Sun Oct 09, 2011 7:53 pm
BTW thanks for that link gooner, looks like I will just be using my pre-fl starter then. I at least know that it works.
Post Sun Oct 09, 2011 11:26 pm
E30_Crazy wrote:BTW thanks for that link gooner, looks like I will just be using my pre-fl starter then. I at least know that it works.
Connect the black/green to the 13mm nut on the solenoid closest to the motor body.
E30_Crazy
Post Mon Oct 10, 2011 12:26 am
Will do, thanks Brian. After the starter motor change, just need to fill her up with coolant, top off the oil, and should be good go. Give it a couple days to wake back up and get back into the motions, then see what she can do :twisted:
