Sunroof seal replacement....
rover-2000
Post Thu Sep 29, 2011 8:30 am
Guys
I think I already know the answer, but.....
Can the sunroof seal (Panel to roof) be replaced without removing the sunroof? If not, how easy is it to remove? Our seal has come apart..... :(
Thanks.
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
**BANNED**
Post Thu Sep 29, 2011 9:25 am
You need to remove the sunroof lid.
Open the roof a few inches.
Carefully pop the liner off at the front edge and allow it to slide back into its cavity.
Close the roof and put it to full tilt position.
Examine the sides of the mech now exposed and you will see three torx-headed screws on each side.
Remove these and lift the panel off.
Seals are available as a one piece and a two piece(front and back)The one piece is far less painfull to buy than the two piece.
Fitting is a simple remove the old and press the new on.
Re-assembly to the car is a Mr Haynes reversal of the above..... :D
Except winkeye
1.The 6 mounting screws allow adjustment of the lid,level at the front and a touch low at the back.
2.When offering up the liner to it's fixing,lift the back of it slightly so that it engages on the tilt levers and allows the liner fully forward.
Job should take an hour or so,enjoy.
Youth is wasted on the young.
rover-2000
Post Thu Sep 29, 2011 9:39 am
That doesn't sound too bad... (Famous last words!) 8O
Are the seals both genuine and interchangeable?
Thanks.
Kind regards
John
1989 320i Touring
**BANNED**
Post Thu Sep 29, 2011 10:05 am
rover-2000 wrote:That doesn't sound too bad... (Famous last words!) 8O
Thanks.
Yes and yes,only from your local friendly stealer as well.
Been a while since I bought one of these seals,so no idea of current cost.
rover-2000
Post Thu Sep 29, 2011 1:08 pm
Thanks very much. Will enquire.....
Kind regards
John
1989 320i Touring
