325 auto to manual conversion
luckylee
Hi guys thinking of converting my 325i sport auto to a manual I have a donor car which is a standard 325i are the boxes the same ? And what will this entail? I'm fairly capable mechanic but would be nice to know of any probs Im gonna come across, any tips ?
Jim320i
- E30 Zone News / COTM Team
When you say are the boxes the same? Do you mean, will the manual bolt straight on when you take off the auto, if so, yes it will...
If you mean is the a manual sports box different from a standard 325 one, if so, the sport uses the same Getrag 260 box but with closer ratios
You'll also need;
Driveshaft
Flywheel
Master/slave cylinders
Lines needed between manual and slave cylinders
Shift linkage parts
Gearstick etc
Clutch pedal set up
Clutch kit
I think...
Not sure about the electrical side of things like the ECU but i'm sure they are the same.
You'll also need;
Driveshaft
Flywheel
Shift linkage parts
Gearstick etc
Clutch pedal set up
Clutch kit
I think...
mattrs
When we did my mates one it wouldn't start after, iirc a live wire to the starter rectified this...Bit heath robinson, but it got us out of trouble!
the only wiring needed is to bypass/remove the inhibiter loom that goes to the starter, it's a black/yellow wire behind the glovebox
don't forget you will need a spigot bearing ! and the prop that matches the manual box
Jim320i
e30topless wrote:the only wiring needed is to bypass/remove the inhibiter loom that goes to the starter, it's a black/yellow wire behind the glovebox
Forgot spigot bearing
- **BANNED**
On the wiring side,the inhibit loom splits the black/yellow start signal wire at a connector behind the glovebox as already written.The two plain black wires should be removed from the black/yellow,and the two black/yellows joined together,one is male,and un-suprisingly the other is female.The two blacks lead to a relay under the accesories socket and are fed from the accesories socket,then a sub-loom disappears under the carpet to emerge at a plug at the auto selector,at this plug you will also find the plug for the reversing lights,a two wire lead disappearing toward the rear of the car.Remove as much of the inhibitor circuit as possible,and connect the reverse light switch wire that will enter the car via the rubber gearstick gaiter.If your auto is a 'swichable' one(switch mounted on the handbrake console)you will need to trace this loom as well,the ECU hides in the boot somewhere.
Sport 'boxes have slightly different ratios for the three lower gears,and are valuable because of this.The standard 'box will be fine,though.
If you have access to a car lift,you will probably be able to reach the top bellhousing bolts and do the swap with the engine in the car,if like me,you are working at home on the drive,it may well be easier to pull the lot out and swap the box on the floor.
Youth is wasted on the young.
emdog16
Avid E30 Nut, and Scientist of all things that go BOiiiNGGGG.
If you want to go mental on your shocks... check out ForRacingUseOnly.com
