cone air filter
pcs
Post Tue Sep 20, 2011 7:58 am
Hi....can anyone tell me if there is any advantage in fitting a cone air filter, over the standard set-up on a 1990 325. I've heard this described as an upgrade?.............thanks
DHFiS
Post Tue Sep 20, 2011 8:06 am
Changing to a cone filter will not show any power gains.
pcs
Post Tue Sep 20, 2011 8:12 am
Thanks for the reply. So apart from no power gain, is there reason why anyone would bother? I'm told there is better throttle response, but am beginning to wonder if there is any advantage.
groovylee
Post Tue Sep 20, 2011 8:13 am
more induction noise, but not much else unless coupled with some other mods. the noise sounds good to start with, but soon gets on your nerves.............
pcs
Post Tue Sep 20, 2011 8:17 am
Okay...........suspected other mods may be required. Thanks, appreciate the reply
Post Tue Sep 20, 2011 8:20 am
No advantage at all, whatever mods it's combined with! More likely to show a small power loss, since it will be sucking in warmer under bonnet air.
pcs
Post Tue Sep 20, 2011 8:27 am
Fantastic......thanks for this. Will stop entertaining any idea of fitting one.
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Sep 20, 2011 9:06 am
Ed China has a lot to answer for...
Ajsingh
Post Tue Sep 20, 2011 2:54 pm
I had one on my 2.7.... Did it no favours, its feels alot better with the oem box and filter back on.
E30 Crazy!
pcs
Post Tue Sep 20, 2011 9:55 pm
Thanks.........appreciate the replys. Will be sticking with the standard set-up for sure
