Prices please
Looking for genuine BMW parts at discounted prices? Try here!
bmwe30mtech
Post Mon Sep 19, 2011 10:37 pm
Prices for the following, in the listed quantities, please:
51231864963 x2 (clips for bonnet strut)
07119904295 x6 (nuts for topmounts)
51481938725 x18 (rivets for bonnet insulation)
34321154322 x2 (grommets for brake pipe holes in wings)
63131376873 x1(front indicator lens)
63131376874 x1(front indicator lens)
71212122014 x1 (label for coil)
61217564274 x1 (battery holder long bolt+clamp)
51711380390 x1 (engine loom support harness for bulkhead)
61131369373 x1 (cable holder)
07146949380 x3 (body nuts for gearbox heat shield)
11611308862 x1 (intake manifold bracket)
51711933125 x4 (clamps for side skirts)
25117519669 x1 (bearing sleeve for gearbox shift)
25117571899 x2 (clips for gearshift)
25111220439 x4 (plastic washer for gearshift)
32411126321 x1 (bracket for power steering reservoir)
32411093596 x8 (crush washers for steering)
17222245358 x2 (0 rings for oil cooler pipes)
51112232040 x13 (plastic nuts for front lower splitter)
51131872146 x8 (metal clips for front grills)
12521710729 x1 (diagnostic plug bracket)
31351127202 x2 (supports for front ARB rubber mounts)
34341163565 x4 (clips for pipe)
64508390602 x2
64508390601 x6
64508390603 x1
64508390604 x1
Cotswoldbmw
Post Tue Sep 20, 2011 11:48 am
Hi There
51231864963 x2 (clips for bonnet strut) £0.83 for 2
07119904295 x6 (nuts for topmounts) £1.24 for 6
51481938725 x18 (rivets for bonnet insulation) £2.92 for 18
34321154322 x2 (grommets for brake pipe holes in wings) £1.18 for 2
63131376873 x1(front indicator lens) £8.32
63131376874 x1(front indicator lens) £8.32
71212122014 x1 (label for coil) £0.59
61217564274 x1 (battery holder long bolt+clamp) £9.82
51711380390 x1 (engine loom support harness for bulkhead) £13.28
61131369373 x1 (cable holder) £1.49
07146949380 x3 (body nuts for gearbox heat shield) £0.76 for 3
11611308862 x1 (intake manifold bracket) £14.76
51711933125 x4 (clamps for side skirts) £6.48 for 4
25117519669 x1 (bearing sleeve for gearbox shift) £7.44
25117571899 x2 (clips for gearshift) £0.83 for 2
25111220439 x4 (plastic washer for gearshift) £0.61 for 4
32411126321 x1 (bracket for power steering reservoir) £5.41
32411093596 x8 (crush washers for steering) £3.37 for 8
17222245358 x2 (0 rings for oil cooler pipes) £4.52 for 2
51112232040 x13 (plastic nuts for front lower splitter) £3.24 for 13
51131872146 x8 (metal clips for front grills) £2.59 for 8
12521710729 x1 (diagnostic plug bracket) £6.37
31351127202 x2 (supports for front ARB rubber mounts) £6.77 for 2
34341163565 x4 (clips for pipe) £2.56 for 4
64508390602 x2 £1.88 for 2
64508390601 x6 £7.20 for 6
64508390603 x1 £0.95
64508390604 x1 £1.27
Prices inc. E30Zone Discount and VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 24140
There is a P&P cost of £1.99 on all orders under £20
Please remember if you require an urgent response drop our
Parts Department an email
partscheltenham@cotswoldgroup.com
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
